It is currently Mon Jul 28, 2025 1:23 pm
PostPosted: Mon Aug 25, 2008 7:29 pm
While squaring up my sides the other day I noticed I could easily make the sides (below the waist on the flat part) flex by pushing on them in the middle... is this normal? It's a LMI kit with pre-bent sides, I think they were about .095" thick. I also put bias tape strips in there with fish glue. Will they stiffen up once the porefiller,shellac, and tru-oil go on?
And no, it's not because I sanded the sides too thin.
Jeremy Douglas
PostPosted: Mon Aug 25, 2008 7:46 pm
No problem Jeremy my friend if your sides are around .095 some softness when one tries to press a thumb into a side with moderate or more pressure is not a problem. Mahogany can do this as can other woods too.
The real purpose of the side tapes is to arrest a side crack from traveling not to stiffen the sides.
Your cool. [:Y:]
PostPosted: Mon Aug 25, 2008 8:40 pm
Thanks. Having seen this I couldn't imagine not using any kind of side reinforcement. Spruce braces don't seem like a bad idea.
Jeremy Douglas
PostPosted: Mon Aug 25, 2008 9:21 pm
ToddStock wrote:
Lots of guitars without. My D-15 has .075 sides which will flex at least 1/8" in the flats...it's fine, and will probably outlast me.
My all mahogany Larrivee OM has no side supports but there's no flex that I can see. I wouldn't be surprised if the Larrivee had really thick sides though.
Jeremy Douglas
